mad
- PranešimaiCOLON 1
- UžsiregistravoCOLON 2013 10 08, 00:03
- AutomobilisCOLON mitsubishi
Neperskaitytas pranešimas
Roliz » 2013 10 08, 09:31
4M41[edit]
Engine type — Inline 4-cylinder DOHC 16 valve
Displacement — 3200 cc
Bore — 98.5 mm
Stroke — 105.0 mm
Fuel type — Diesel
Intercooled turbo[edit]
Fuel system — Electronic control type distributor type pump (direct injection inside diesel tube) or Common Rail Direct Injection
Compression ratio — 17:1
Power — 121 kW (165 PS) at 4000 rpm
Torque — 351 N·m (259 lb·ft) at 2000-3000 rpm
Applications:
1999-2006 Mitsubishi Pajero
2005-2011 Mitsubishi Triton / L200 / Strada
2006-2007 Mitsubishi Pajero (Philippine Domestic Market)
2008-2011 Mitsubishi Pajero Sport / Montero Sport
1st Generation Variable geometry intercooled turbo[edit]
Fuel system — Common Rail Direct Injection
Compression ratio — 17:1, 16.0:1
Power — 129 kW (175 PS) at 3800 rpm
Torque — 382 N·m (282 lb·ft) at 2000 rpm
Applications:
2006-2009 Mitsubishi Pajero (currently on the Philippine Domestic Market Pajero)
2nd Generation Variable geometry intercooled turbo[edit]
Power —147 kW (200 PS) at 3800 rpm
Torque — 450 N·m (330 lb·ft) at 2000 rpm
Applications:
2010–present Mitsubishi Pajero
