Mitsubishi Eclipse (GT ir GS modeliu, 2006+) Gamykliniu (yra dvi: paprasta140W ir premium 650W) audio sistemu duomenys:
STANDARD ROCKFORD FOSGATE AUDIO SYSTEM
• Single-disc CD player for MP3/CD-R/CD-RW
• AM/FM digital radio
• MAX output: 140W
• Six speakers total:
• 2 x 1.25" (3.5cm) tweeters (dash-top panel)
• 2 x 6x9" front (door speakers)
• 2 x 6.25" rear (rear quarter panels)
PREMIUM ROCKFORD FOSGATE AUDIO SYSTEM
• 6-disc in-dash CD player for MP3/CD-R/CD-RW
• So-called "Digital Signal Processor" (DSP)
• Audio amplifier (under glove box)
•MAX output: 650W
•Steering wheel with remote control radio switches
• Advertised nine speakers total (in 7 distinct locations):
• 2 x 6.25" front (door speakers)
• 2 x 6.25" 2-way rear (rear quarter panels)... the "8th and 9th" speakers
• 9.75" (25cm) subwoofer (trunk enclosure)
Audio Electrical / Signal information
• Electrical dedicated 12v switched power from steering column ignition to Head Unit
• 12v ignition to relay/fuse box: blue-black wire
• Fused 12v (under-dash fusebox) to HU: blue wire
• Box fuse = 15A (#23)
• Electrical dedicated 12v from battery to RF 650W amp
• 12v battery to relay/fuse box: white wire
• Fused 12v (under-dash fusebox) to amp: red-green wire
• Box fuse = 30A (#12)
• Speaker signal / power
• Standard System (all speaker power from HU)
• LH front tweeter: white-blue (+) / black-blue (-) ... [shares same power/ground as front LH door speaker, parallel]
• LH door speaker: white-blue (+) / black-blue (-)
• RH tweeter: white-red (+) / black-red (-) ... [shares same power/ground as front RH door speaker, parallel]
• RH door speaker : white-red (+) / black-red (-)
• LH rear speaker : yellow-blue (+) / gray-blue (-)
• RH rear speaker : yellow-green (+) / white (-)
• 650W Premium System
• From amplifier:
• Subwoofer coil 1: gray (+) / red-blue (-)
• Subwoofer coil 2: green-red (+) / red (-)
• From HU:
• LH tweeter: white-blue (+) / black-blue (-)
Pajungimo schemos:
Standartines (be stiprintuvo)
Premium (su stiprintuvu)
Audio isdestymo schema:
Koloneliu tvirtinimas (montavimas)
Audio Klaidu kodai:
Mago tvirtinimas (montavimas)
Vairo audio valdymo schema:
Priedas, norintiems pasikeisti audio "galva", bet kad derintusi su Premium sistema (stiprintuvu)...
