Galant ryklių galerija
- scheichas
- PranešimaiCOLON 2410
- SkypeCOLON scheichas
Re: Galant ryklių galerija
nesvarbu, gerulis vistiek
Owner : Andy Connection
Car : Mitsubishi Galant Cobra Concept
Exterior Modification :
Special FRP model front bumper, Special Kevlaring model front hood, Special Reinforced carbon model front fender, Special Renforced carbon model door, Special galvanis model skirt, Special FRP model rear bumper, Special Kevlaring model rear lamp, Special front lamp model diffuser, Special galvanis model rear wide fender, Custom chop roof, Custom 2 door conversion, Kirkey Alumunium Wing, VR4 Left head lamp, Acrylic 3mm all glass, Sparco gianci trunk pid, Sparco gianci hood pid, F1 model kevlar side mirror.
Engine Modification :
Engine block 4G63T 6 bolt, Cylinder Head 4G63T 7bolt, Gearbox 4G63T, Toyota supra rear axle, Four wheel drive conversion, Turbo Garret GT 35 R ball bearing, Trust Intercooler, Haltech E11 V2 Engine Management, Haltech Version Upgrade Software, Haltech sensor map 5 bar, Summit surge tank, Summit fuel tank(15l), Summit fuel line, AEM fuel rail, Polyurethane engine mounting, Wiseco 86mm Piston, Wiseco Piston ring, Eagle conrod, Eagle crankshaft, ARP cam bearing, ARP head stud, ARP Cylinder head stud, ARP rod bolt, HKS adjustable cam gear, HKS spring valve and retainer, HKS gasket metal, HKS timing belt, HKS blow off valve, HKS wastegate, HKS injector 1500cc/minutes, HKS Plug, HKS drag lowering kit, HKS Silicon hose, ACL main bearing, ACL rod bearing, Ferrea valve and guide, Unorthodox pulley kit, Stainless turbo pipe 2.5 inch, Turbo XS exhaust manifold, Custom exhaust pipe 4inch stainless, B&K throttle body, Direct coil ignition, Magnus intake manifold plenum, Paxton Fuel Pressure regulator, Aeromotive A1000 Fuel pump, Bosch 0.44 Fuel Pump, Cusco oil catch tank, Ralliart oil filter, Earl's Oil hose, Earl's Alumunium radiator, Earl's braided line, Earl's fuel filter, Greddy Oil cooler, Pivot radiator cap, Blitz oil cap, Samco coolant kit housing, ACT extreme clutch 6PUCKS, ACT Chromoly Flywheel, John Shepperd fork, John Shepperd gear 2 trans spec, John Shepperd hub/sleeve kit, John Shepperd double synchro ring, John Shepperd Synchro spring, John Shepperd drive shaft seal, John Shepperd input shaft bearing, John Shepperd intermediate gear bearing, John Shepperd center diff sideshim, B&M quick shift, APEX'I AFC-R boost meter.
Color Spec :
Airbrush cobra, Basecoat : Kustom Kandies Apple by House of Kolor, Illumi effect : Dorado to Redo Chameleon Kolor by House of Kolor, Green Xirallic by SpiesHecker, BC 216 base white by House of Kolor, Yellow Kandies by House of Kolor, Multilayer Clearcoat by Sikkens High Solid P35.
Interior :
Apex'I AFC-R boost meter, Rollbar seamless 1.5 inch, Sparco drag sterring wheel, Custom conversion Left sterring, Momo pedal set, Momo shift knob, Custom flooring bordess, Folia-TEC engine cut off, Custom dashboard laminated with carbon illumi brush, Indicator autometer pro-comp(oil temp. oil press, volt meter, boost meter, water temp), Custom reinforced all deck.
Rolling Stock :
Volk Rays GTC 8,5"front ; 10.5"rear, Toyo Proxes T1-S 275/30z front, Toyo Proxes T1-s 245/35z rear.
Brake and Suspension :
Toyota Supra rear axle, Four wheel drive conversion, HKS drag lowering kit, John Shepperd fork, John Shepperd gear 2 trans spec, John Shepperd hub/sleeve kit, John Shepperd double synchro ring, John Shepperd Synchro spring, John Shepperd drive shaft seal, John Shepperd input shaft bearing, John Shepperd intermediate gear bearing, John Shepperd center diff sideshim, Wilwood 4 pot front brake kit, Ralliart rear brake kit, Cusco strut bar front and rear, Custom Chrome (stabilizer, tromol,knuckle, swing arm, ball joint, tie rod, oil pan, alternator, engine cover, etc).
Audio System :
Alpine DVA head unit, Custom boombox drag model, Venom 1500 XD, Venom Black power monoblock, Venom coaxial middle speaker, Venom Subwoofer 12" 2 pcs, 7" oris monitor, Custom paint boom box Apple Kandies, Monster cable.
- Marozas66
- PranešimaiCOLON 2946
- AutomobilisCOLON Vag'enas
- SkypeCOLON Sharhanas
Dar pasakyk, kad jis tau grazus, tai kita kart nuleisiu rata ir zapaske pavogsiu
Idejau kaip eksponata
Priekis idomus. Nissan skyline R34 primena.
- Marozas66
man tai kosmosas
sudie zapaskei!!!
sudie zapaskei!!!
Siaip ratai negrazus
bet kazkaip tinka sitam
- nearealus
- PranešimaiCOLON 1489
- SkypeCOLON nearealus
- MiestasCOLON Šilale
- Sky'us
- PranešimaiCOLON 3305
- AutomobilisCOLON MG
- MiestasCOLON Sun City
Ner dropo, ner. Ir va sitam tikrai ratai nei i tvora, nei i meta.
- scheichas
nu jo, VR-4 be dropo, geda...
- Marozas66
Lempos tinka. Netinka grotelių vertikalios pertvaros
- snapsazs
- PranešimaiCOLON 6497
lempos good ir seip good
