Puslapis 1 iš 42
Eclipse 2G galerija ("Grazuole 2G")
ParašytasCOLON 2008 02 13, 09:44
1/4 Mile ET: 11.206
1/4 Mile MPH: 124.600
1/8 Mile ET: 7.187
1/8 Mile MPH: 95.400
0-60 Foot ET: 1.400
Temperature F: 80.0
Timeslip Scan:
Car Make: Mitsubishi
Car Model: Eclipse
Car Type: gsx
Car Year: 1999
Horsepower @ wheels: 450.00
Torque @ wheels: 406.00
Engine: 4g63
Turbos: pte dual bb 57 trim
Supercharger:
Boost Control: greddy profect b
Boost Pressure (psi): 24
Intercooler: greddy xl
Nitrous System: none
Nitrous Shot:
Pistons (rotors): stock
Port:
Rings (seals): stock
Heads: stock
Connecting Rods: stock
Camshaft: hks 272s
Throttle Body: 62 mm
Intake & Air Filter: dejoin tool 3 inch
Headers (downpipe): apexi
Midpipe:
apexi
Exhaust: apexin n1
Computer ECU Chip Upgrade: apexi s-afc
Battery: stock
Ignition: magncor wires
Spark Plugs: ngk
Fuel Injectors:
Fuel Pump: walboro 255
Gas: 93
Pulley: stock
Transmission: stock
Clutch/Torq Conv: act 2600
Differential: stock
Radiator: stock
Flywheel: fidanza
Shifter: bm
Gears: stock
Suspension: eibach
Wheels: 17 adr wheels
Brake Rotors/Pads: stock
Tires bfgoodrich kd
Weight with driver (lbs): 3500
Re: Eclipse 2G galerija ("Grazuole 2G")
ParašytasCOLON 2008 02 13, 10:58
nu liuxas
ParašytasCOLON 2008 02 13, 14:03
Vo sita tai uzskaitau
.. Koks tai "Ninja Edition"
ParašytasCOLON 2008 02 13, 14:08
weetux
Nakti nė nematyt tokios musiet
ParašytasCOLON 2008 02 13, 16:00
Nasas
o va cia tai rimta
juoda juoda
ParašytasCOLON 2008 02 13, 16:43
ProXas
Ka tik apseilejau klaviatura
Blem koks lektuvelis mielas...
ParašytasCOLON 2008 02 13, 18:14
`Tadas`
labai grazi,mmm..
ParašytasCOLON 2008 02 13, 23:42
Jei teks garbe turet 2G ateity, tai visom 5iom stengsiuos, kad atrodytu va stai taip ! Tobula
ParašytasCOLON 2008 02 14, 01:10
LtuDsm
idomu kiek tam pirmam eclipsiu layke variklis bei greiciu deze???!!! :DD
ParašytasCOLON 2008 02 21, 00:31
1997 Eagle Talon TSI AWD
Bolt on Mods
Evo intake
SBR front mount intercooler
Greddy type RS BOV
60mm TB
Comp "272" cams
SBR Tublar manifold
Turbo Smart wastegate
Magnus heat gasket
B&M short throw shifter
Shep stage 3 tranny
SBR tubular O2 housing
RSR 3" catless exhaust
6an fuel line
Walbro 255 Fuel pump
Razo weighted shift knob
Engine
6-bolt swap
Pauter rods
PTE 5031 Dual BB turbo
Ross Pistons 8.5:1
rebuilt head
3G lifters
Denso 660 injectors
ARP rod bolts
ARP head studs
Suspension
Koni yellow adjustables
H&R Springs
RMDSM sway bars
Axis Reverb 18” wheels
Prothane bushings
Prothane motor mounts
Management
DSM Link
Aeromotive FPR
Autometer oil pressure gauge
Autometer oil temp gauge
Autometer boost gauge
Autometer volt gauge
Autometer water temp gauge
Turbo Smart boost controller
HKS Type II turbo timer
Additional Mods
Alpine white paint
Eclipse Conversion
Rally Art front lip
Buddy Club 2 side skirts
VIS carbon hood
Sparco steering wheel
PLX wideband O2
Panasonic head unit
Scroth Rally I 2
Sony xplode 480w amp
Panasonic components
Sparco Turino seats
Polk GNX 10” sub
Battery relocated
Optima red top
Performance
396Horse power
350 ft. Lbs. Tourque
On DynoJet
90 Degree day on 93 octane
Best pass 1/4
11.8 @ 116 mph
1.6 60ft
On pump gas and 215 50 r17 street tires
Projekto nuotraukos:
http://www.snailspeedcarclub.com/daves97talontsiawd.htm
ParašytasCOLON 2008 02 21, 00:50
ParašytasCOLON 2008 02 21, 04:50
LtuDsm
Kevinai,Tas Talonas su Eclipses kebulu,bei tas Eclipsas su zemu spoleru ir grafikom ant sonu as tuos savininks zinau,tas raudnas eclipsas priklauso vieno is New Jersey DSM clubo nariu,o Kitas baltas tas talonas su eclipses kebulu priklauso Philly dsm clubo nariui lol
ParašytasCOLON 2008 02 21, 08:11
pasistengė kevinas
ParašytasCOLON 2008 02 21, 11:28
Gal ne visos jos tokios grazuoles, bet parinkau ivairiasniu variantu, tiesiog kad paziuret kazka kitokio.
350 WHP DSM Owner rašėCOLONKevinai,Tas Talonas su Eclipses kebulu,bei tas Eclipsas su zemu spoleru ir grafikom ant sonu as tuos savininks zinau,tas raudnas eclipsas priklauso vieno is New Jersey DSM clubo nariu,o Kitas baltas tas talonas su eclipses kebulu priklauso Philly dsm clubo nariui lol
Na vakar atradau tokiu mazesniu usa forumu, kur tikrai idomus zmones su pavydetinais projektais. Prasymas tau: padaryt kada nors normalia savo dabartinio 1G foto, labai man idomu, aciu
ParašytasCOLON 2008 02 21, 16:06
LtuDsm
padarysiu iskart,kaip tik susitvarkysiu motora,nes dabar tai nieko nematysi,viskas isardyta ir kaip metalo lauzo kruva atrodo :DD
