M_actep
PranešimaiCOLON 789
UžsiregistravoCOLON 2009 01 05, 20:22
AutomobilisCOLON galant90
SkypeCOLON mactep_ccc
MiestasCOLON Kaišiadorys-Dremmen
Re: Grazios masinytes (...man labai patinka, bet ne mitsubishi)
Neperskaitytas pranešimas M_actep » 2009 05 27, 19:04
Man ta audines matine spalva gerai atrodo :drool: Kaip idomu atrodytu galanchiuka taip nudazhius? :mrgreen:
Colt 90m 44kW shrote
Galant 89 m 55 kW shrote
Neperskaitytas pranešimas Lukas » 2009 05 28, 00:02
kasrupi rašėCOLONjeigu matine, tai tik visa - gautusi per didelis vinigretas, jei dar paliktum pusiau matine pusiau blizgancia
Na dar popsava yra daryti matinę mašiną su blizgančiais vinilais ar dažymu tokiu:
Neperskaitytas pranešimas kasrupi » 2009 05 28, 01:07
wow, atrodo gal ir neblogai, tik neisivaizduoju saves uz jos vairo. :P
Neperskaitytas pranešimas Matosas » 2009 05 28, 08:23
Andriuha rašėCOLONo jusu nuomone ar salia lakuotos raudonos dera matine juoda ar geriau juoda lakuota ? :roll:
kadangi aš esu matinės spalvos vergas, tai mano nuomone matinė
Neperskaitytas pranešimas Kevinas » 2009 05 29, 15:20
2003 Mitsubishi Tarmac Spyder
Neperskaitytas pranešimas Lukas » 2009 05 29, 15:25
Neperskaitytas pranešimas Kevinas » 2009 06 02, 15:51
The Savage Rivale Roadyacht GTS regardless based on the Corvette, it comes equipped with a supercharged LS7 V8 engine that’s good enough for 670HP at 6,200 rpm and 538 lb-ft of torque at 4,800 rpm launching the four door hardtop cabrio from zero to 100km/h (62mph) in just 3.4 seconds and on to a theoretical top speed of 330km/h or 205mph. Power is transferred to the rear wheels through GM-sourced automatic gearbox. The car burden is still relatively low at 1,280 kg. Custom-made Tenzo 19-inch are wrapped in Toyo T1R tires. Braking is provided by DBM, with eight-piston and four-piston monoblocks, gripping 380mm or 355mm discs.
Companies lending their assistance to the predict includes Eindhoven, Netherlands, based Motio development, who aided with the 3D modelling. Komplot Mechanics complete the foam moulds, while Rep-air Composites helped with the body panels. Steel juggernaut Corus provided equipment for the framework. Pop and de Boer expect to produce 20 units of the Savage Rivale Roadyacht GTS.
Neperskaitytas pranešimas ZND007 » 2009 06 02, 17:26
kai piktas 8O 8O 8O
Neperskaitytas pranešimas Tomukas999 » 2009 06 04, 14:10
Neperskaitytas pranešimas kasrupi » 2009 06 04, 14:12
Tomukas999 rašėCOLONPaveikslėlis
man tik ju balsas nepatinka - netgi ir su Schniceliais
Neperskaitytas pranešimas JanZi » 2009 06 08, 15:17
2 different ages, 2 different legends :D
Neperskaitytas pranešimas Mantas » 2009 06 08, 15:40
C3 :tt1: :tt1: :tt1:
Neperskaitytas pranešimas Kevinas » 2009 06 08, 15:55
Grazus talonas, kas :censored: pajuriu vazineja! :twisted:
Neperskaitytas pranešimas Vyckele » 2009 06 08, 19:56
Kai ta numeri ale evo taip krivalakiskai prisuka sone, tai cia gaidys visai jau :D ir nereik knist proto kad per vidury IC uzstoja...
Neperskaitytas pranešimas Kevinas » 2009 06 08, 21:11
Vyckele rašėCOLONKai ta numeri ale evo taip krivalakiskai prisuka sone, tai cia gaidys visai jau :D ir nereik knist proto kad per vidury IC uzstoja...
Vat butent, kad uzstoja. Bet to talonu buferio forma, kad kitur ir netinka numeriai uzdeti.
