Eclipse 2G galerija ("Grazuole 2G")
Re: Eclipse 2G galerija ("Grazuole 2G")
Jei ne sita eclipse is F&F, tai Lietuvoj niekas ir siandien nezinotu apie 2G
- ZLODEY
- PranešimaiCOLON 1182
tiesa! bl@, negalejo kokia normalesne masina pasirinkt
OOOO S4 + d4
CBR600RR
CBR600RR
Mods:
Exterior
-OEM black housing head lights with 8k HIDs
-Mitsu. Badging removed
-ViS OEM C/F hood
-Sparco hood pins
-Carbon fiber fenders
-Carbon Fiber trunk
-Removed OEM wing
-Carbon fiber windshield wiper cowl
-Carbon fiber fuel door
-Carbon fiber fog light delete covers
-Carbon fiber exhaust shield
Engine:
-Evo III motor swap
-HKS 264/272 Cams
-Skunk 2 Cam Gears
-Cometic Head gasket
-ARP Head studs
-C.O.P setup
-1990 External Oil cooler
-Gates Racing Timing Belt
-Brian Crower Springs/Retainers
Turbo:
-PTE 50 trim w/ polished comp. housing
-Slowboy Racing 3.5" FMIC
-Slowboy Racing Short route piping w/ blowthrough setup
-Greddy Type RS BOV
-SS oil feed line
-SS Oil Drain
Engine Management:
-`03 Evo VIII ECU, tuned with EcuFlash
-Apexi S-AFC
-Greddy Turbo Timer
-Innovate Wideband O2 sensor and gauge
-AEM Tru Boost EBC
-Snow Performance SafeInjection
-Snow Performance Wastegate bypass solenoid
-Snow Performance meth injection gauge
-Dynatek Arc 2 CDI box
Drivetrain:
-ACT 2600 Pressure Plate
-Clutchnet 6 puck sprung disc
-ACT Streetlite Flywheel
-SS clutch line
-GSX axles
-Welded Center Diff by ShepTrans
-SBR LSD insert
-Fidanza Short shifter
-Symborski Shifter kit
-Aluminum Shifter Cable bushings
Fuel:
-Walbro 255lph fuel pump w/ rewire
-PTE 1000 CC injectors
-Fuel Lab AFPR with return kit
-AEM High Flow Fuel Rail
-6An fuel fittings w/ braided lines
-Snow Performance Stage 2 Water/Meth Injection w/ 2.5 gallon tank
Cooling:
-Punishment Racing Aluminum Radiator w/ slim fans
-Gates Racing Thermostat
-Gates Racing Radiator hoses
-JMFab coolant tank
Exhaust:
-Forced Performance Race Exhaust manifold
-3" exhaust
-Megan Racing 3"downpipe w/ cat eliminator
-Punishment Racing O2 w/ Atmospheric Dump
Air Intake:
-K&N Air Filter
-JMFabrications SMIM
-3.5" MAF with MAF-T
-Forced Performance 4" Air Intake
-1g 60mm Throttle Body
-JMFab oil catch can
Engine Dress Up
-Black Krinkle Hyundai Valve cover
-Braided Lines
- JMFab Mini Battery kit
Suspension
-17" Evo IX Enkei wheels
-Yokahama Advan tires
-Ksport Pro Kontol Coilovers
-Rotora 4 piston Big Brake kit
-Rear disc brake conversion (not yet installed)
-Moroso Front upper strut bar
-Prothane motor mounts
Interior:
-Top Shop carbon's C/F door panels
-C/F Center Console
-C/F kick panels
-Alpine IDA-X001 headunit
-Pioneer speakers
-Bride Gias Low Max seats
-Sparco 310x260 racing steering wheel
-Sparco 3pt Harnesses
-NRG Real c/f shift knob
- domkisz
- PranešimaiCOLON 368
- UžsiregistravoCOLON 2008 11 02, 16:32
- AutomobilisCOLON eclipse 1g
- SkypeCOLON domkisz
- searchas
- PranešimaiCOLON 7
- UžsiregistravoCOLON 2008 09 22, 16:13
- AutomobilisCOLON Mitsubishi Eclipse 98m 2000 GS
- MiestasCOLON Rdv
Dar siek tiek
Tai ir 2G targų buvo?
- tomarinas
- PranešimaiCOLON 1613
- AutomobilisCOLON 1g, e36
- SkypeCOLON Tomaz911
buvo, bet sita nesiziuri, turbut kad spoilerio nera
- PranešimaiCOLON 3884
- AutomobilisCOLON cb5a
Nebuvo. Matos už sėdynės metalinis korpusas įdėtas dar neperlūžtų. Nemažai usa yra tokių pridaryta.Fever rašėCOLONTai ir 2G targų buvo?
- tomarinas
aj tiksliai
taigi spyder yra
- searchas
- PranešimaiCOLON 7
- MiestasCOLON Rdv
dar kelios targa
- tomarinas
bet cia samadielkos
- searchas
- PranešimaiCOLON 7
- MiestasCOLON Rdv
nu jo, matos dar 2g baltos, kad gumos negražiai nupjautos. Nebent buvo 1g tu targa...
Lankai sudėti dėl saugumo, targoj kėbulo stiprumą laiko dugnasorangen rašėCOLONNebuvo. Matos už sėdynės metalinis korpusas įdėtas dar neperlūžtų. Nemažai usa yra tokių pridaryta.
