TCL kas tai?
ParašytasCOLON 2006 01 07, 13:22
Andrius Sigma
labas visiem, pas mane SIGMA bet man atrodo kad ir pas kitus yra tas navarotas TCL gal galit kasnors apie tai papasakoti?
ParašytasCOLON 2006 01 07, 14:22
Nasas
TCL tai yra antiprabuksavimo sistema.Traction control angliškai vadinasi.
pasiskaityk va biski aiškiau bus :
In 1990, Mitsubishi released the Diamante (Sigma) in Japan. Featured among the innovations geared for active safety was the new, world first, Traction ControL (TCL) system. TCL was developed to help the driver maintain the intended line through a corner. An onboard computer monitors several vehicle operating parameters through various sensors. When too much throttle has been used when taking a curve, engine output is automatically reduced to prevent the vehicle from overshooting. TCL also includes a standard wheel slip control function for better traction on slippery surfaces or during cornering. In addition to the TCL system's individual effect, it also works together with electronic controlled suspension and four-wheel steering to improve total handling and performance.
Vaizdinė medžiaga
ParašytasCOLON 2006 01 08, 20:28
labai geras dalykas ziema. pas draugeli ant bumerio yra, tai nepakeiciamas dalykas masinai su varomu galu.
ParašytasCOLON 2006 01 10, 13:27
Andrius Sigma
Jo dabar aisku ko ji taip stabiliai per sniega lekia, vaziuoji 120 suspaustu sniegu apsoliuciai nenesioja, stovi anta kelio kaip prikalta.
ParašytasCOLON 2006 01 10, 15:22
pas mumberi ji vadinasi ASC anti-sliping control
ParašytasCOLON 2006 01 11, 13:45
Andrius Sigma
Bet kai man idejo tas jobanas dujas ir kai vaziuoji ant duju tai v ant skydelio uzsidega TCL of tai reiskia vaziuojant ant duju TCL nedirba ane
ParašytasCOLON 2006 01 11, 14:05
Andrius Sigma rašėCOLONBet kai man idejo tas jobanas dujas ir kai vaziuoji ant duju tai v ant skydelio uzsidega TCL of tai reiskia vaziuojant ant duju TCL nedirba ane
jei be rusiškų keiksmų, tai jos tikria tokios, bet ar gali tam turėti įtakos būtent dujos
a tai jis užsidega kai tik tada kai ant dujų važiuoji
ar jis tik dega ar ir neveikia
ParašytasCOLON 2006 01 11, 15:06
Tai todėl ir dega, kad neturi ko valdyti, nes prie dujų valdymo bloko ta sistema neprijungta. O gal pas tave išviso neteisingos dujos kaip ir mano mašinoj(be įpurškimo)?
ParašytasCOLON 2006 01 12, 14:00
Andrius Sigma
Duju yranga paprasta ne taskine :( kai vaziuoju ant benzino viskas gerai dega zale lempute kuri rodo jog TCL ijungta, bet kai perjungiu ant duju uzsidega chek engaine ir TCL OFF tai kaip suprantu tada TCL nebedirba, oi oi tos dujos tik vargas.
ParašytasCOLON 2006 01 12, 14:04
Andrius Sigma rašėCOLONDuju yranga paprasta ne taskine
nu taigi mpegas labai aiskiai paporino kodel tau neveikia tcl. tsakant butu tavo kompas ne toks banalus tai jau butu seniai pasakes 'fsio eikit po velniu, as daugiau isviso nebeveiksiu jei dar su dujomis vazinesi
atimat is manes galimybe kontroliuoti variklio galia, ir dar norit kad tcl veiktu, nu i na :laught03:
Andrius Sigma rašėCOLONoi oi tos dujos tik vargas.
BŪTENT
ParašytasCOLON 2006 01 13, 12:51
Andrius Sigma
Nu jo matau kad Sigmute ant manes supyko uz tas dujas, kogero reikes jas traukti lauk, kaip is karto nepagalvojau, 1300 kaip i sik... is vis dujos masinoi - masinos negerbimas.
