2001 plasma Speedo gauge in 97 galant
ParašytasCOLON 2011 04 01, 11:58
RL.
Hello neighbors. I am Mitsu fan from the Latvian
I would like to ask you if Galant GDI 2000 year speedometer new plasma panel fits in the 1997 Galant GLS.
i want this like, only from manual gearbox.
and i have, with t10 bulbs. sorry but picture doesn't.
Re: 2001 plasma Speedo gauge in 97 galant
ParašytasCOLON 2011 04 01, 12:15
We know for sure, that the one from V6 Galant does not fit to 2.0 ones... So I guess it could be the same with GDI.
ParašytasCOLON 2011 04 01, 15:00
scheichas
I don't think so Dzhedaj, you see, 2.0 and GDI has four cilinders, so there should be no problems with tachometer, but it is just my opinion.
ParašytasCOLON 2011 04 01, 15:25
Why do you think the problem is because of the cylinder count? Shouldn't the sensor be in the gearbox?
ParašytasCOLON 2011 04 01, 15:33
RL.
Then come that, can not fit only tachometer, with a V6 engine? But like scheichas says GDI are 4 cilinders, maybe fits.
and gearbox sensor, with GDI not same? I guess GLS gearbox senor go to ECU then go to speedometer, and doesn't incorrect reading to plasma speedo from GDI.
I doesn't know what to do, buy or not, that GDI plasma panel is not so cheap!
ParašytasCOLON 2011 04 01, 16:08
scheichas
in my case, everything worked(water temp unit, fuel unit, speedometer, and counted kilometers correctly) except tachometer, but when I inserted it into V6 Galant, tachometer worked splendidly
ParašytasCOLON 2011 04 01, 16:23
RL.
That is interesting. I heard in Latvia to, that problem is tachometer, but i don't know what kinda plasma speedo been from, maybe v6 or GDI!
ParašytasCOLON 2011 04 01, 16:30
scheichas
need to try and you'll see if everything works :) that's everything I could tell you, good luck :)
ParašytasCOLON 2011 04 01, 16:53
RL.
That all I need to hear of you! :) Thanks!
I later post there my results of speedo fitting!
ParašytasCOLON 2011 04 01, 21:08
scheichas
I'll be waiting :)
ParašytasCOLON 2011 04 02, 15:05
The gearbox sensors are the same in 2.0, 2.5 and gdi. 2.0 Techo signal is different from 2.5 cuz ignition system, so gdi display may fit to 2.0 :)
ParašytasCOLON 2011 04 02, 23:07
scheichas
that's what I'm trying to say :D
