Nulaužiau rato "spilka"- ka daryt?
ParašytasCOLON 2008 06 18, 21:05
Erix
taip jau gavosi, kad atsukant Carismos rata, verzle nusisuko su "spilka".
Ratas dabar priverztas su trim verzlem - nesaugu. Ar imanoma ja pakeist, kita idet ar reikia visa "stupitsa" keist.
Ar jos skiriasi 1,6 ir 1,8 varikliu? Gal kas turit parduot? :D
P.S.Gal zinot kur Carismos Manual'a rast, forume duoti link'ai neatsidaro. Aciū!
Re: Nulaužiau rato "spilka"- ka daryt?
ParašytasCOLON 2008 06 18, 21:22
"Špylkos" daugumos Mitsubishių vienodos (o gal ir visų).
Senos kas liko iškali lauk, važiuoji šrote nusiperki kitą ir ten pat atgal sukali.
ParašytasCOLON 2008 06 19, 08:37
Rubinas
Kam srote.. Kad Lirostoj ar kur.. kainuoja pora litu. Tik geriau issikalk ir pasiimk.. nes ismatavimus reik zinoti. Stori ir sriegio tanki :-D
Nuemimas paprastas, jei instrumentus turi. Suportus nuemi.. nusuki apsaug..ir iskali.. poto ikali ir surenki ;)
Teko keisti jau kokias 5 :)
ParašytasCOLON 2008 06 20, 00:57
Sorry, kad nera vertimo, bet... ;)
Mitsi Club Regular
Found on net.
what you need:
1. regular sized socket wrench
2. 17mm socket
3. whatever you normally use to get the lugs off(i have a torque wrench i use, but the wrench with the spare works fine)
4. hammer
5. a extra lug you dont care about, or a nut that will screw completely down on the stud without hitting the wheels.
6. new stud. its about 1.70 at hyundai parts. you may want to pick up another lug too, as one will get damaged(but is still perfectly useable) if you cant find a appropriate nut. a lug/stud pack is like 4 bucks i think.
7. whatever beer you like, just dont make it corona, that crap tastes like rat piss. Wink
Steps:
1. Remove wheel
2. Remove the Caliper from the knuckle. you do not need to remove the bolts that hold the actual caliper together, just the ones that hold it to the knuckle. i pointed to the one on top that you need to remove, just find the other one on the bottom and take that one off too.
3. if the rotor will slide off easily, then take it off. it will just get in the way if its bobbling around everywhere. if it doesnt come off, dont worry, you will just have to reach around it a tad bit more. mine slid off fine, because i put zinc coated rotors on, and because i sprayed some caliper paint on the hub.
4. rotate the hub so that the damaged stud is not in front of the cover.
5. hammer backwards until it pops out. it shouldnt be too hard to get out, even if you do live where the roads are salted. new stud vs. old stud
6. stick the new stud through the hole and hold it in place with your hand. screw on whatever lug you dont care about as much as you can with your hand. then screw it down enough so you can get the lug on it with the wheel and rotor on(you will see it start pushing the top of the lug up). i wrapped the hammer with a rag, and then put it underneath one of the other studs to keep the thing from spinning(be careful not to damage the threads though).
7. put the rotor back on if you took it off, bolt the caliper back down to the knuckle after sliding it over the rotor, and put the wheel back on. tighten down all the lugs as much as you can(so that the wheel doesnt move, lower the car enough so that the wheel wont spin, and completely tighten them. after a couple days of driving, make sure the lug on the stud that you repaired is still on tightly. yeah, i need to get another lug.
_________________
ParašytasCOLON 2008 06 21, 11:21
Erix
Pasirodo visai paprasta paciam pasikeist. :o
Dekui uz pagalba!
Kai tik rasiu laisvo laiko, pulsiu ardyt :wink:
ParašytasCOLON 2009 04 05, 17:41
Katerina
o man reik viso stupico su tom shpilkom. juos po viena parduoda? eclipse 2G
ParašytasCOLON 2009 04 06, 13:13
Galant2l
Katerina rašėCOLONo man reik viso stupico su tom shpilkom. juos po viena parduoda? eclipse 2G
Taip jos parduodamos po viena. Bet paprastai jos buna su rato guoliais.
ParašytasCOLON 2009 04 06, 21:42
Katerina
aishku aciu, dar teko laimes snd suzhinot kad pas mane talonas..
ParašytasCOLON 2009 04 06, 21:45
Ausriukas
Katerina rašėCOLONaishku aciu, dar teko laimes snd suzhinot kad pas mane talonas..
katerina o ko tau nereikia??? :lol: gal tu ishkart visa mashina keiskis bus paprasciau :lol:
ParašytasCOLON 2009 04 06, 21:58
Katerina
tai matai ish tokiu piz***rankiu nupirkau visa perdaryta tai db vargstu. bet patika ji man labai.
