Nulaužiau rato "spilka"- ka daryt?
- PranešimaiCOLON 3
- UžsiregistravoCOLON 2008 06 18, 20:39
- AutomobilisCOLON Carisma 1.8
taip jau gavosi, kad atsukant Carismos rata, verzle nusisuko su "spilka".
Ratas dabar priverztas su trim verzlem - nesaugu. Ar imanoma ja pakeist, kita idet ar reikia visa "stupitsa" keist.
Ar jos skiriasi 1,6 ir 1,8 varikliu? Gal kas turit parduot?
P.S.Gal zinot kur Carismos Manual'a rast, forume duoti link'ai neatsidaro. Aciū!
Re: Nulaužiau rato "spilka"- ka daryt?
"Špylkos" daugumos Mitsubishių vienodos (o gal ir visų).
Senos kas liko iškali lauk, važiuoji šrote nusiperki kitą ir ten pat atgal sukali.
- Rubinas
- PranešimaiCOLON 381
- UžsiregistravoCOLON 2007 01 30, 00:05
Kam srote.. Kad Lirostoj ar kur.. kainuoja pora litu. Tik geriau issikalk ir pasiimk.. nes ismatavimus reik zinoti. Stori ir sriegio tanki
Nuemimas paprastas, jei instrumentus turi. Suportus nuemi.. nusuki apsaug..ir iskali.. poto ikali ir surenki
Teko keisti jau kokias 5
Carisma HB 98m EXE Pilkuma
- kasrupi
- PranešimaiCOLON 1811
- AutomobilisCOLON FTO
- SkypeCOLON kasrupi
- MiestasCOLON US Florida
Sorry, kad nera vertimo, bet...
Mitsi Club Regular
Found on net.
what you need:
1. regular sized socket wrench
2. 17mm socket
3. whatever you normally use to get the lugs off(i have a torque wrench i use, but the wrench with the spare works fine)
4. hammer
5. a extra lug you dont care about, or a nut that will screw completely down on the stud without hitting the wheels.
6. new stud. its about 1.70 at hyundai parts. you may want to pick up another lug too, as one will get damaged(but is still perfectly useable) if you cant find a appropriate nut. a lug/stud pack is like 4 bucks i think.
7. whatever beer you like, just dont make it corona, that crap tastes like rat piss. Wink
Steps:
1. Remove wheel
2. Remove the Caliper from the knuckle. you do not need to remove the bolts that hold the actual caliper together, just the ones that hold it to the knuckle. i pointed to the one on top that you need to remove, just find the other one on the bottom and take that one off too.
3. if the rotor will slide off easily, then take it off. it will just get in the way if its bobbling around everywhere. if it doesnt come off, dont worry, you will just have to reach around it a tad bit more. mine slid off fine, because i put zinc coated rotors on, and because i sprayed some caliper paint on the hub.
4. rotate the hub so that the damaged stud is not in front of the cover.
5. hammer backwards until it pops out. it shouldnt be too hard to get out, even if you do live where the roads are salted. new stud vs. old stud
6. stick the new stud through the hole and hold it in place with your hand. screw on whatever lug you dont care about as much as you can with your hand. then screw it down enough so you can get the lug on it with the wheel and rotor on(you will see it start pushing the top of the lug up). i wrapped the hammer with a rag, and then put it underneath one of the other studs to keep the thing from spinning(be careful not to damage the threads though).
7. put the rotor back on if you took it off, bolt the caliper back down to the knuckle after sliding it over the rotor, and put the wheel back on. tighten down all the lugs as much as you can(so that the wheel doesnt move, lower the car enough so that the wheel wont spin, and completely tighten them. after a couple days of driving, make sure the lug on the stud that you repaired is still on tightly. yeah, i need to get another lug.
_________________
Mitsi Club Regular
Found on net.
what you need:
2. 17mm socket
4. hammer
Steps:
1. Remove wheel
_________________
Paskutinį kartą redagavo 1 kasrupi. Iš viso redaguota 2009 kartus.
- PranešimaiCOLON 3
Pasirodo visai paprasta paciam pasikeist.
Dekui uz pagalba!
Kai tik rasiu laisvo laiko, pulsiu ardyt
Dekui uz pagalba!
- PranešimaiCOLON 81
- UžsiregistravoCOLON 2008 10 24, 19:52
- AutomobilisCOLON Eclipse 2G USA
o man reik viso stupico su tom shpilkom. juos po viena parduoda? eclipse 2G
- Galant2l
- PranešimaiCOLON 289
- SkypeCOLON aurimasm.y
Taip jos parduodamos po viena. Bet paprastai jos buna su rato guoliais.Katerina rašėCOLONo man reik viso stupico su tom shpilkom. juos po viena parduoda? eclipse 2G
Mitsubishi galant glsi - sold
Mazda xedos6 v6
Mazda xedos6 v6
aishku aciu, dar teko laimes snd suzhinot kad pas mane talonas..
- PranešimaiCOLON 5203
- AutomobilisCOLON Subaru
katerina o ko tau nereikia??? gal tu ishkart visa mashina keiskis bus paprasciauKaterina rašėCOLONaishku aciu, dar teko laimes snd suzhinot kad pas mane talonas..
Jaguar XJ8 4.0 V8 parduota
Subaru Impreza
Subaru Impreza
tai matai ish tokiu piz***rankiu nupirkau visa perdaryta tai db vargstu. bet patika ji man labai.
