420A
4G63
1) 420a bus sunkiau su detalėmis, kai tuo tarpu 4G63 tokių problemų neturi visiškai. Tai tokie ir skirtumai, jog visiškai skirtingi varikliai.
2) Teisingai
3) Čia atmosferinis variklis, kurio kodas 420A.
Krc, gal aiškiau bus su galiom ir komplektacikom:
The Eclipse was available in seven trim levels: Base [Only available in 1996.5 (mid-model year)], RS (Rally Sport), GS (Grand Sport), GS Spyder, GS-T (Grand Sport Turbo), GS-T Spyder, and GSX (Grand Sport X=AWD).
Eclipse RS: Base FWD model equipped with a 140 hp 2.0 L 16-valve DOHC Chrysler 420a engine
Eclipse GS: Equipment upgraded FWD model equipped with a 140 hp (100 kW) 2.0 L 16-valve DOHC Chrysler 420A engine. The European variant of the GS had a naturally aspirated, DOHC 16 valve 4G63 engine producing 150 HP with FWD
Eclipse GS Spyder: Convertible FWD model equipped with a 141 hp (105 kW) 2.4 L 16-valve SOHC Mitsubishi 4G64 engine
Eclipse GS-T: Hardtop FWD model equipped with a 210 hp (160 kW) turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine
Eclipse GS-T Spyder: Convertible FWD model equipped with a 210 hp (160 kW) turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine
Eclipse GSX: AWD model equipped with a 210 hp (160 kW) turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine
The models had different trim accoutrements:
Base - No tachometer, standard antenna, No rear defroster, no driving lights, 14-inch steel wheels with covers or center caps, vinyl trimmed seats, rear drum brakes
RS - Tachometer, 14-inch alloy wheels, optional spoiler
GS - Power antenna, driving lights, cruise control, body coloured door handles, 15-inch alloy wheels (95-96 models), 16-inch alloy wheels (97-99 models), lower body cladding, spoiler, rear windshield washer
GS Spyder - Power antenna, driving lights, cruise control, body coloured door handles, 16" alloy 5 spoke wheels, lower body cladding, spoiler, double tipped stainless steel exhaust
GS-T - 16" Alloy 5 spoke wheels, Grey painted panel around lower body paneling (1995–96), "low rise" spoiler (95-96), "high rise" spoiler (1997–99), double tipped stainless steel exhaust
GS-T Spyder - 16" Alloy 5 spoke wheels, double tipped stainless steel exhaust, "low rise" spoiler for all years.
GSX - 17-inch wheels after 1997, 1995–96 cars had 16-inch alloys, Grey painted panel around lower body paneling (1995–96), double tipped stainless steel exhaust, "low rise" spoiler(95-96), larger spoiler (1997–99), vented rear rotors (early 95) with dual piston front calipers.
