Mitsubishi varikliu specifikacijos
- kasrupi
- PranešimaiCOLON 1811
- AutomobilisCOLON FTO
- SkypeCOLON kasrupi
- MiestasCOLON US Florida
Nukopijavau sia info is savo klubo, bet gal kam idomu ar bus naudinga. Jei kur rasite klaidu - pataisykite. Jei si info jau kur nors yra - istrinkite.
4G11 8-valve SOHC 1.2 litre
Available in: ??
Bore x Stroke: ??
Piston Displacement: ??
Compression Ratio: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G12 8-valve SOHC 1.4 litre
Available in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G13 12-valve SOHC 1.3 litre specs
Can be found in: CA, CJ
Bore x Stroke: 71.0 x 82.0 mm
Piston Displacement: 1298cc
Compression Ratio: 9.5:1
Max Power: 55kW @ 6000rpm (redline 6500rpm - limiter 6750rpm)
Max Torque: 108Nm @ 4000rpm
Horse power: 74(CA)
Torque: 80(CA)
4G13 16-valve SOHC 1.3 litre specs
Can be found in: CJ
Bore x Stroke: 71.0x82.0 mm
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G15 12-valve SOHC 1.5 litre specs
Bore x Stroke: 75.5 x 82.0mm (2.97" x 3.23")
Piston Displacement: 1468cc
Compression Ratio: 9.2:1
Max Power: 69kW @ 5500rpm
Max Torque: 126Nm @ 3000rpm
Horse power: 92
Torque: 93
4G15 12-valve DOHC 1.5 litre specs
Can be found in: CJ
Bore x Stroke: 75.5 x 82.0 mm
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G15 16-valve DOHC 1.5 litre Turbo specs
Can be found in: CZ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G61 16-valve DOHC 1.6 litre specs
Can be found in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G63T 16-valve DOHC 2.0 litre Turbo specs
Can be found in: Lancer Evo's
Bore x Stroke: 85.0 x 88.0
Piston Displacement: 1997cc
Compression Ratio: 8.5:1/8.8:1/9.0:1
Max Power: ??
Max Torque: ??
Horse power: 210-405
Torque: ???
4G67 16-valve DOHC 1.8 litre specs
Can be found in: ??
Bore x Stroke: ??
Piston Displacement: 1836cc
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G91 16-valve DOHC 1.5 litre specs
Can be found in: CA
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G92 16-valve SOHC 1.6 litre specs
Bore x Stroke: 81x77.5 mm
Piston Displacement: 1597cc
Compression Ratio: 10.0:1
Max Power: 83kW @ 6000rpm
Max Torque: 137Nm @ 5000rpm
Horse power: 111
Torque: 101
4G92 16-valve DOHC 1.6 litre MIVEC specs
Bore x Stroke: 81.0 x 77.5 mm
Compression Ratio: 11.0:1
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G93 16-valve SOHC 1.8 litre specs
Can be found in: Spacewagon/runner/Galant/Pinin
Bore x Stroke: 81.0 x 89.0 mm
Piston Displacement: 1834cc
Max Power: 86kW @ 5500rpm
Max Torque: 161Nm @ 4500rpm
Horse power: 113
Torque: 116
4G93 16-valve DOHC 1.8 litre specs
Can be found in: CA/Proton
Bore x Stroke: 81.0 x 89.0mm
Compression Ratio: 10.5:1
Max Power: 103kW @ 6000rpm (redline 7000rpm - limiter 8000rpm)
Max Torque: 167Nm @ 5500rpm
Horse power: 138
Torque: 123
4G93T 16-valve DOHC 1.8 litre Turbo specs
Can be found in: CD5 Lancer
Compression Ratio: 9.0:1
Max Power: ??
Max Torque: ??
Horse power: 195-225
Torque: ??
4G94 ??-valve SOHC 2.0 litre specs
Can be found in: AUS Vehicles,Lancer?
Bore x Stroke: 81.5 x 95.8
Max Power: 89kW @ 5500rpm
Max Torque: 176Nm @ 4250rpm
Horse power: 120
Torque: 130
(Info from Wikipedia)
4D68 8-valve SOHC 2.0 litre Diesel
Can be found in: ??
Bore x Stroke: 82.7 x 93.0
Piston Displacement: 1998cc
Compression Ratio: 22.4:1
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4D68T 8-valve SOHC 2.0 litre Turbo Diesel
Can be found in: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
6A10 24-valve DOHC 1.6 litre V6 specs
Can be found in: CJ
Bore x Stroke: 73.0 x 63.6
Max Power: 103kW @ 7000rpm
Max Torque: 147Nm @ 4500rpm
Horse power: 140
Torque: 108
6A11 24-valve SOHC 1.8 litre V6 specs
Can be found in: Galant, Mirage (US)
Bore x Stroke: 75.0 x 69.0
Piston Displacement: 1829cc
Max Power: 99kW @ 7000rpm
Max Torque: 167Nm @ 4500rpm
Horse power: 135
Torque: 123
6A12 24-valve DOHC 2.0 litre V6 specs
Can be found in: FTO/Galant
Bore x Stroke: 78.4 x 69.0
Max Power: (94-96) - 127kW @ 7000 rpm & (97-02) - 132kW @ 7000 rpm
Max Torque: 191Nm @ 4000 rpm
Horse power: (94-96) - 172 & (96-02) - 180
Torque: 141
6A12 24-valve DOHC 2.0 litre V6 MIVEC specs
Max Power: 147kW @ 7500 rpm
Max Torque: 200.4Nm @ 6500 rpm
Horse power: 200
Torque: 147
6A13 24-valve SOHC 2.5 litre V6 specs
Bore x Stroke: 81.0 x 80.8
Piston Displacement: 2498cc
Max Power: 121kW @ 5750rpm
Max Torque: 223Nm @ 4500rpm
Horse power: 165
Torque: 164
6A13TT 24-valve DOHC 2.5 litre Twin-Turbo V6 specs
Can be found in: Legnum, VR4
Max Power: 206kW @ 5500rpm
Max Torque: 363Nm @ 4000rpm
Horse power: 280
Torque: 268
6G72 24-valve DOHC 3.0 litre V6 specs
Can be found in: GTO/UK Sigma
Bore x Stroke: 91.1 x 76.0
Piston Displacement: 2972cc
Max Power: 163kW @ 6000rpm
Max Torque: 272Nm @ 4500rpm
Horse power: 222
Torque: 201
6G72TT 24-valve DOHC 3.0 litre Twin-Turbo V6 specs
Can be found in: GTO/3000GT/Dodge Stealth
Compression Ratio: 8.0:1
Max Power: 221kW @ 6000rpm
Max Torque: 415Nm @ 2500rpm
Horse power: 300
Torque: 307
Available in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Available in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 74(CA)
Torque: 80(CA)
Can be found in: CJ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 92
Torque: 93
Can be found in: CJ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: CZ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Max Power: ??
Max Torque: ??
Torque: ???
Can be found in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: CA
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 111
Torque: 101
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 113
Torque: 116
Horse power: 138
Torque: 123
Max Power: ??
Max Torque: ??
Torque: ??
Horse power: 120
Torque: 130
Can be found in: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: CJ
Horse power: 140
Torque: 108
Horse power: 135
Torque: 123
Torque: 141
Horse power: 200
Torque: 147
Horse power: 165
Torque: 164
Horse power: 280
Torque: 268
Horse power: 222
Torque: 201
Horse power: 300
Torque: 307
- Falk3n
- PranešimaiCOLON 1434
- AutomobilisCOLON e46 328i
- MiestasCOLON Alytukas
Re: Mitsubishi varikliu specifikacijos
Keista bet paprasciausio 4g63 neuzmaciau
Info tai labai nepilna ir praktiskai viska ta pati wikipedijoj gali susirasti...
- LtuDsm
- PranešimaiCOLON 461
- SkypeCOLON ltudsm
- MiestasCOLON Philadelphia
na as ir kazkaip nepamaciau 4g63 bei nera kiek matau 420A ??!!!
O 420A nuo kada Mitsubishi variklis?
- LtuDsm
- SkypeCOLON ltudsm
nuo 1995-1999Dzhedaj rašėCOLONO 420A nuo kada Mitsubishi variklis?
Taip, bet variklis taip kaip ir Chryslerio
- LtuDsm
- SkypeCOLON ltudsm
nu gerai dar paziurekDzhedaj rašėCOLONTaip, bet variklis taip kaip ir Chryslerio
- kasrupi
O kam wikipedijoj, jei cia galima butu susirasti? Ir juk paminejau, kad info galetu buti pataisyta - galima ir papildyti. Su tokia ideja kazkas UK klube ta pati pradejo daryti - butu idomus galutinis variantas. O dabar kritikos susnis plustelejo. Juk dar paminejau, kad istrinkite, jei kas ne taip.Dzhedaj rašėCOLONInfo tai labai nepilna ir praktiskai viska ta pati wikipedijoj gali susirasti...
Tai mes netrinam, o patariam, kad nepilna informacija nera ypatingai naudinga kai kada
- LtuDsm
- SkypeCOLON ltudsm
AgTs-4587 8-valve DOHC 1.0 litre TurboDIESEL specs
Can be found in: Lada GT-S
Bore x Stroke: 25.0 x 28.0
Piston Displacement: 1217cc
Compression Ratio: 2.5:1/8.1:1/4.0:1
Max Power: su geru benzu 2.5 ag
Max Torque: 2 ft-lbs
Horse power: 7-9
Torque: 4-6
LADA GT-S
Horse power: 7-9
Torque: 4-6
- kasrupi
Kazkas is klubo nariu klause manes ar buna UK COLT'u su MIVEC varikliais. Pradejau tuo dometis ir UK klube automatiskai atsirado toks linkas kaip MITSUBISHI ENGINES SPEC. su primityvia info. Bet laikui begant tikiu, kad ta info pasipildys ir taps nepaprastai naudinga. Klubo nariams nereikies klaidzioti po neta ir ieskoti. Tam tik reikia laiko ir geranoriskumo, o ne kritikos.
Pamaniau, kad bus idomu kazka panasaus pasiulyti padaryti ir cia, bet... Veikiant dviem frontais, UK ir LT, info surinkimas butu kur kas greitesnis - cia zmones nieko nenutuokia apie Eclipses.
Bet matau, kad nelabai pavyko experimentas.
Pries paviesindamas kokia nors minti, dabar butinai pasitarsiu.
- LtuDsm
- SkypeCOLON ltudsm
o ten UK 4g63 varikliais domisi kasnors???
- kasrupi
Dar nemaciau tiek EVO kaip paskutiniame mini meet'e si savaitgali. Turbut, kad domisi.
- LtuDsm
- SkypeCOLON ltudsm
As turejau omeny kaip Eclipsem ar Talonkasrupi rašėCOLONDar nemaciau tiek EVO kaip paskutiniame mini meet'e si savaitgali. Turbut, kad domisi.
