Mitsubishi varikliu specifikacijos
ParašytasCOLON 2008 01 17, 01:30
Nukopijavau sia info is savo klubo, bet gal kam idomu ar bus naudinga. Jei kur rasite klaidu - pataisykite. Jei si info jau kur nors yra - istrinkite.
4G11 8-valve SOHC 1.2 litre
Available in: ??
Bore x Stroke: ??
Piston Displacement: ??
Compression Ratio: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G12 8-valve SOHC 1.4 litre
Available in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G13 12-valve SOHC 1.3 litre specs
Can be found in: CA, CJ
Bore x Stroke: 71.0 x 82.0 mm
Piston Displacement: 1298cc
Compression Ratio: 9.5:1
Max Power: 55kW @ 6000rpm (redline 6500rpm - limiter 6750rpm)
Max Torque: 108Nm @ 4000rpm
Horse power: 74(CA)
Torque: 80(CA)
4G13 16-valve SOHC 1.3 litre specs
Can be found in: CJ
Bore x Stroke: 71.0x82.0 mm
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G15 12-valve SOHC 1.5 litre specs
Bore x Stroke: 75.5 x 82.0mm (2.97" x 3.23")
Piston Displacement: 1468cc
Compression Ratio: 9.2:1
Max Power: 69kW @ 5500rpm
Max Torque: 126Nm @ 3000rpm
Horse power: 92
Torque: 93
4G15 12-valve DOHC 1.5 litre specs
Can be found in: CJ
Bore x Stroke: 75.5 x 82.0 mm
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G15 16-valve DOHC 1.5 litre Turbo specs
Can be found in: CZ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G61 16-valve DOHC 1.6 litre specs
Can be found in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G63T 16-valve DOHC 2.0 litre Turbo specs
Can be found in: Lancer Evo's
Bore x Stroke: 85.0 x 88.0
Piston Displacement: 1997cc
Compression Ratio: 8.5:1/8.8:1/9.0:1
Max Power: ??
Max Torque: ??
Horse power: 210-405
Torque: ???
4G67 16-valve DOHC 1.8 litre specs
Can be found in: ??
Bore x Stroke: ??
Piston Displacement: 1836cc
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G91 16-valve DOHC 1.5 litre specs
Can be found in: CA
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G92 16-valve SOHC 1.6 litre specs
Bore x Stroke: 81x77.5 mm
Piston Displacement: 1597cc
Compression Ratio: 10.0:1
Max Power: 83kW @ 6000rpm
Max Torque: 137Nm @ 5000rpm
Horse power: 111
Torque: 101
4G92 16-valve DOHC 1.6 litre MIVEC specs
Bore x Stroke: 81.0 x 77.5 mm
Compression Ratio: 11.0:1
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4G93 16-valve SOHC 1.8 litre specs
Can be found in: Spacewagon/runner/Galant/Pinin
Bore x Stroke: 81.0 x 89.0 mm
Piston Displacement: 1834cc
Max Power: 86kW @ 5500rpm
Max Torque: 161Nm @ 4500rpm
Horse power: 113
Torque: 116
4G93 16-valve DOHC 1.8 litre specs
Can be found in: CA/Proton
Bore x Stroke: 81.0 x 89.0mm
Compression Ratio: 10.5:1
Max Power: 103kW @ 6000rpm (redline 7000rpm - limiter 8000rpm)
Max Torque: 167Nm @ 5500rpm
Horse power: 138
Torque: 123
4G93T 16-valve DOHC 1.8 litre Turbo specs
Can be found in: CD5 Lancer
Compression Ratio: 9.0:1
Max Power: ??
Max Torque: ??
Horse power: 195-225
Torque: ??
4G94 ??-valve SOHC 2.0 litre specs
Can be found in: AUS Vehicles,Lancer?
Bore x Stroke: 81.5 x 95.8
Max Power: 89kW @ 5500rpm
Max Torque: 176Nm @ 4250rpm
Horse power: 120
Torque: 130
(Info from Wikipedia)
4D68 8-valve SOHC 2.0 litre Diesel
Can be found in: ??
Bore x Stroke: 82.7 x 93.0
Piston Displacement: 1998cc
Compression Ratio: 22.4:1
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
4D68T 8-valve SOHC 2.0 litre Turbo Diesel
Can be found in: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
6A10 24-valve DOHC 1.6 litre V6 specs
Can be found in: CJ
Bore x Stroke: 73.0 x 63.6
Max Power: 103kW @ 7000rpm
Max Torque: 147Nm @ 4500rpm
Horse power: 140
Torque: 108
6A11 24-valve SOHC 1.8 litre V6 specs
Can be found in: Galant, Mirage (US)
Bore x Stroke: 75.0 x 69.0
Piston Displacement: 1829cc
Max Power: 99kW @ 7000rpm
Max Torque: 167Nm @ 4500rpm
Horse power: 135
Torque: 123
6A12 24-valve DOHC 2.0 litre V6 specs
Can be found in: FTO/Galant
Bore x Stroke: 78.4 x 69.0
Max Power: (94-96) - 127kW @ 7000 rpm & (97-02) - 132kW @ 7000 rpm
Max Torque: 191Nm @ 4000 rpm
Horse power: (94-96) - 172 & (96-02) - 180
Torque: 141
6A12 24-valve DOHC 2.0 litre V6 MIVEC specs
Max Power: 147kW @ 7500 rpm
Max Torque: 200.4Nm @ 6500 rpm
Horse power: 200
Torque: 147
6A13 24-valve SOHC 2.5 litre V6 specs
Bore x Stroke: 81.0 x 80.8
Piston Displacement: 2498cc
Max Power: 121kW @ 5750rpm
Max Torque: 223Nm @ 4500rpm
Horse power: 165
Torque: 164
6A13TT 24-valve DOHC 2.5 litre Twin-Turbo V6 specs
Can be found in: Legnum, VR4
Max Power: 206kW @ 5500rpm
Max Torque: 363Nm @ 4000rpm
Horse power: 280
Torque: 268
6G72 24-valve DOHC 3.0 litre V6 specs
Can be found in: GTO/UK Sigma
Bore x Stroke: 91.1 x 76.0
Piston Displacement: 2972cc
Max Power: 163kW @ 6000rpm
Max Torque: 272Nm @ 4500rpm
Horse power: 222
Torque: 201
6G72TT 24-valve DOHC 3.0 litre Twin-Turbo V6 specs
Can be found in: GTO/3000GT/Dodge Stealth
Compression Ratio: 8.0:1
Max Power: 221kW @ 6000rpm
Max Torque: 415Nm @ 2500rpm
Horse power: 300
Torque: 307
Available in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Available in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 74(CA)
Torque: 80(CA)
Can be found in: CJ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 92
Torque: 93
Can be found in: CJ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: CZ
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Max Power: ??
Max Torque: ??
Torque: ???
Can be found in: ??
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: CA
Bore x Stroke: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 111
Torque: 101
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Horse power: 113
Torque: 116
Horse power: 138
Torque: 123
Max Power: ??
Max Torque: ??
Torque: ??
Horse power: 120
Torque: 130
Can be found in: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: ??
Max Power: ??
Max Torque: ??
Horse power: ??
Torque: ??
Can be found in: CJ
Horse power: 140
Torque: 108
Horse power: 135
Torque: 123
Torque: 141
Horse power: 200
Torque: 147
Horse power: 165
Torque: 164
Horse power: 280
Torque: 268
Horse power: 222
Torque: 201
Horse power: 300
Torque: 307
