3G eclipse variklio dirzeliai ir guoliai is JAV
- Wytska
- PranešimaiCOLON 4899
Taigi, ilgai ieskojau kol sudariau pilna sarasa visu dirzeliu ir guoliu OEM ka reikia keisti
Taigi 2.4litro varikliui:
GATES Part # K050370 {Automotive V-Ribbed Belt (Standard) 5 Ribs 21/32" x 37 3/4"} Generatoriaus dirzelis - $10.77
GATES Part # K050538 {Automotive V-Ribbed Belt (Standard) 5 Ribs 21/32" x 54 3/8"} Oro kondicionieriaus dirzelis - $16.30
GATES Part # K050429 {Automotive V-Ribbed Belt (Standard) 5 Ribs 21/32" x 43 1/2"} Vairo stiprintuvo dirzelis - $13.98
GATES Part # T168 {Automotive Timing Belt 1/2" x 20 1/2" (65 Teeth)} Balansinio veleno dirzelis - $12.83
GATES Part # T232 {Automotive Timing Belt 1 5/32" x 46 1/8" (123 Teeth)} Paskirstymo dirzelis - $31.79
GATES Part # T41054 {Timing Belt Tensioner Steel Smooth (60mm x 10mm x 33mm) - Flanged} Paskirstymo dirzelio itempimo skriemulys be itempejo - $55.89
GATES Part # T42017 {Timing Belt Pulley Steel Smooth (60mm x 10.5mm x 32mm)} Paskirstymo dirzelio tusciaeigis skriemulys - $16.50
GATES Part # T41038 {Timing Belt Tensioner Steel Smooth (55mm x 8.5mm x 18.5mm) - Flanged} Balansinio dirzelio itempimo skriemulys - $17.71
Viso $175 + Global express mail 48$ = $223 + 10% muitas + 18% PVM....
Taigi 3.0litru varikliui: (gerokai pigiau prasisuks savininkai)
GATES Part # K040355 {Automotive V-Ribbed Belt (Standard) 4 Ribs 9/16" x 36 1/8"} Vairo stiprintuvo dirzelis - $8.83
GATES Part # K060470 {Automotive V-Ribbed Belt (Standard) 6 Ribs 13/16" x 47 5/8"} Generatoriaus ir oro kondicionieriaus dirzelis - $14.52
GATES Part # TCK259 { 3 Components (1 Belt, 1 Tensioner, 1 Idler)} Paskirstymo dirzelis su itempejo ir tuscios eigos skriemuliais - $65.79
Balansinio veleno V6 variklis neturi.
Viso $89.14 + Global express mail $31 = $120 + 10% muitas + 18% PVM
Jei kas susidomejo ir nori pirkti, rasykit, susimesim, bus pigiau pasto siuntos.
O tu tik butinai 3G dalis "uzsakinesi", ar ir 2G tinka? Nes jei tinka, tai man Talonui reiketu tempiklio skriemulio ir "laisvos eigos" skriemulio. Kaip supratau, daliu ieskojai per rockauto.com ? Man tie skriemuliai pagal juos kainuotu ~50 baksu.
- RenataGT
- PranešimaiCOLON 1332
- UžsiregistravoCOLON 2006 02 21, 14:56
- AutomobilisCOLON Mitsubishi Eclipse '00
- SkypeCOLON mazulytee
as irgi ka tik pasikeiciau dirzus..generatoriaus ir vairo stiprintuvo, bo anie eina kartu...
Keiciau Dagryje vieno kaina buvo 41 Lt, o kito - 25 Lt, o uz darba sumokejau 64 Lt...
bo raso ka reikejo nuimt generatoriu i vel uzdet...
Mitsubishi Eclipse '00 3G GT ( Gerai Traukia) - parduota
Yamaha XVS 650
Audi A3
Yamaha XVS 650
Audi A3
- zixelis
- PranešimaiCOLON 1322
- AutomobilisCOLON walking
- MiestasCOLON East London
Re: 3G eclipse variklio dirzeliai ir guoliai is JAV
lyginu kainas pagal mano: vairo stiprintuvo dirzelis - 30 Lt; generatoriaus ir oro kondicionieriaus dirzelis - 60 Lt,Wytska rašėCOLONGATES Part # K040355 {Automotive V-Ribbed Belt (Standard) 4 Ribs 9/16" x 36 1/8"} Vairo stiprintuvo dirzelis - $8.83
va tep
skaiciuokites, ar apsimoka siustis ar ce pat keistis
[away]
