Tiesa ar melas?:) (kad tauposi kuras stabdant pavara)
Ish xtra forumo:
What conditions will cause fuel cut?
There are three conditions under which the DSM ECU will chop fuel.
Engine speed higher than 7500 RPM. This is overrev protection. If your engine rotates faster than the valve springs can pull the valves back up into the head, the pistons could smack into them, causing major damage. Note that simply chopping fuel will not stop the overrev condition if you misshift and the transmission rotates the engine past the revlimit. (The author did this to his friend's M3.)
Engine air flow greater than a certain amount. If the airflow into the becomes too great, the phenomenon by which the MAF counts the air entering the engine starts to break down, missing counts. The factory ECU sets a very conservative limit here. It doesn't need to be as conservative as it is to prevent missing counts. After we removed this limit, we were only able to hit the MAF counting breakdown problem on a first generation DSM with a 20G set to 19 psi on a 3" exhaust.
Engine under high vacuum for more than a couple seconds. This is not a matter of engine safety, but of smog control. Some of the worst smog can occur during engine deceleration. If you are coasting down a steep hill using the engine to help slow you, the ECU will turn off all fuel to the engine to both aid in engine braking and smog production.
cia visuose auto nuo 1500 nutraukiamas tiekimas,ar yra isimciu?wytska rašėCOLONautomobiliuose kur rodomas momentinis kuro suvartojimas sitas dalykas labai puikiai matomas. Jei tik apsuku yra daugiau nei 1500 ir imesta pavara, benzino padavimas yra nutraukiamas.
Audi A3 1.8T
taigi pasiskaityk tą forumą kur linką Korsaras numetėpharaon rašėCOLONcia visuose auto nuo 1500 nutraukiamas tiekimas,ar yra isimciu?wytska rašėCOLONautomobiliuose kur rodomas momentinis kuro suvartojimas sitas dalykas labai puikiai matomas. Jei tik apsuku yra daugiau nei 1500 ir imesta pavara, benzino padavimas yra nutraukiamas.
- Wytska
- PranešimaiCOLON 4899
pats gali labai lengvai patikrinti Vaziuok nuo lengvo kalniuko ant kokiu 60, isimesk 5 begi, ir ziurek i apsukas. Jos pamazu kris (jei kalnas nestatus ajsq hehe), ir priartejus iki ~1500 pajausi truktelejima. Tai reiskia nuo tokiu apsuku pas tave isijunge benzino padavimas. Jeigu truktelejimo nebus, reiskias masina visiskai tupa ir neturi kazka suprantancio kompopharaon rašėCOLON cia visuose auto nuo 1500 nutraukiamas tiekimas,ar yra isimciu?
- Aikste
- PranešimaiCOLON 1116
- SkypeCOLON Aikste
Dar reiketu pamineti kad, stabdymas varikliu 4wd auto yra zymiai smagesnis ir efektyvesnis...............
Todel Korsaras ir sutaupo daugiau kuro.....
Daznai ir agresyviai stabdant varikliu fwd auto turetu atsiliepti pusasiams....
ir dar labai brangias kaladeles pataupoAikste rašėCOLONDar reiketu pamineti kad, stabdymas varikliu 4wd auto yra zymiai smagesnis ir efektyvesnis...............
siaip net Kacergoj stabdant greitai zeminanat pavaras net abs nesuveikia,o masina stoja be jokiu tampymusi, taigi stabdymas varikliu ir dar su 4wd yra labai cool dalykas
- jhonis
- PranešimaiCOLON 1154
- UžsiregistravoCOLON 2004 09 30, 03:00
100 proc. sutinkuKorsaras rašėCOLONir dar labai brangias kaladeles pataupoAikste rašėCOLONDar reiketu pamineti kad, stabdymas varikliu 4wd auto yra zymiai smagesnis ir efektyvesnis...............
