Mantas rašėCOLONVeyron, Koenigsegg ir Zonda vienoj vietoj... Nu nafig,apseilėjau ekraną
Mantai, čia žinok visgi ne Zonda, o jos pagerinta versija Pagani Huayra
Va kad nereikėtų ieškot įmetu info is Wiki. 544 kw
"Pagani Huayra
Main article: Pagani Huayra
Pagani is building an all new car intended to replace the Zonda. It is named Huayra and will debut at the Geneva Auto Show in 2011. Pagani expects to build no more than 40 each year and each will sell for £1,000,000. The engine is a M158 twin-turbo 6.0 Litre V12 from Mercedes' AMG division producing 730 horsepower (544 kW) and 1,100 N·m (810 lb·ft) of torque.[citation needed]. The Huayra has been redesigned from the ground up, but shares many visual qualities with the outgoing Zonda. The top speed has gone up from the 220 mph ( set by the Zonda F Roadster ) to 235 mph, and the 0-60 time is 3.2 seconds.
Official technical data
* Engine: Mercedes-AMG V12 Bi-Turbo M158
* Displacement: 5980 cc
* Power: 730cv
* Torque: 1100 Nm
* Transmission: 7-speed sequential cross. AMT robotic system with driving programs
* Length: 4605mm
* Wheelbase: 2795mm
* Height: 1169mm
* Width: 2036mm
* Dry weight: 1350 kg
* Weight distribution: 44% front 56% rear"
