Partout `94 Mitsubishi Mirage
Parduodamos naujos ir naudotos dalys, automobiliai dalimis, skysčiai, akumuliatoriai, lemputės, alyvos ir kitos eksploatacijos priemonės
Neperskaitytas pranešimas JanZi » 2017 07 21, 04:01
Hello, due to extensive corrosion decided to part out a Dodge Colt / Mitsubishi Mirage / Eagle Summit sedan.
Originally it was an USDM 1.8 manual, then in 2012 it was swapped to 4g63 NA 6bolt.
ATM car is untouched, can be test-driven.
Some goodies:
*) Engine swap with transmission, axles, Ecu and wiring is direct bolt-onto any CA0 or older Colt/Lancer, however, there might be some wiring issues related possible differences in USDM and European body versions.
*) Eibach Lowering springs
*) 2piston front big brakes off 3000GT, with Brembo brake pads and Zimmermann 276mm Mini Cooper discs, approx 8000kms, direct bolt on to any CA0 or CJ0
*) Kosei Seneka Racing r17 lightweight wheels
*) Instrument cluster with tacho
*) hard-to-find body parts, windows and optics.
Can be sold as complete car, (need to be trailered as it will be written off - not road legal), or can be parted out.
Feel free to ask for the parts and items You need.
PM or whatsapp: +37127594214
