FLASH ERROR CODES (elementari ECU diagnostika)
- kasrupi
- PranešimaiCOLON 1811
- AutomobilisCOLON FTO
- SkypeCOLON kasrupi
- MiestasCOLON US Florida
Re: FLASH ERROR CODES
Va ka atkasiau Versti negaliu, nes pas pati galvoje esantis kompas prisirinko error'u po kakar ir veikia tik avariniu rezimu
Error codes
It gives the error codes for the engine but you can also get the codes for the ABS, Traction Control and Tip box in the same way.
The following is from the Chassis Manual.
ABS Codes - Chassis manual section 35B
Check the ABS warning light operates as follows.
1. When the ignition is switched to ON the ABS light should illuminate for about 3 seconds then switch off.
2. When the key is turned to START the light stays on
3. When the key is turned back to ON the light illuminates for about 3 seconds then switches off.
4. If you have anything other than the above check the error codes.
To properly gain the ABS codes you must disconnect the ABS Valve relay which is the top right relay in the engine bay fuse box, looking from the front. After you have removed this you will also get error code 52. Don’t worry, this is normal and will disappear once you replace it. If you find no codes stored but still have a light behaving different from above then it may be the ABS Valve Relay.
Code
11 Front right wheel speed sensor Open circuit
12 Front left wheel speed sensor Open circuit
13 Rear right wheel speed sensor Open circuit
14 Rear left wheel speed sensor Open circuit
16 Power supply system Low battery
21 Front right wheel speed sensor Short circuit
22 Front left wheel speed sensor Short circuit
23 Rear right wheel speed sensor Short circuit
24 Rear left wheel speed sensor Short circuit
31 Front right ABS sensor rotor Defective teeth
32 Front left ABS sensor rotor Defective teeth
33 Rear right ABS sensor rotor Defective teeth
34 Rear left ABS sensor rotor Defective teeth
41 Front right solenoid valve
42 Font left solenoid valve
43 Rear right solenoid valve
44 Rear left solenoid valve
51 Valve relay problem Stays on
52 Valve relay problem Stays off
53 Motor relay problem Stays off
54 Motor relay problem Stays on
55 Motor system Seized pump motor
63 ABS – ECU
TCL codes - Chassis manual section 13C
To check the system using the TCL lamps assuming both are functioning.
Ignition switch at ON – both lights should light up.
Start the engine and both should switch off
With the engine idling switch of the TCL and the TCL OFF light should illuminate
With the TCL on drive for a few minutes at 30 MPH and no lights should come on.
Anything other than this and you should check for codes as shown above.
Code
11 APS Circuit system
12 APS or TPS Circuit system
13 TPS Circuit system
23 Stop lamp switch circuit system
24 TCL switch circuit system
26 Ignition switch (IG2) system
27 TCL-ECU power supply voltage circuit (engine control relay circuit) system
31 Front right wheel speed sensor circuit system
32 Front left wheel speed sensor circuit system
33 Rear right wheel speed sensor circuit system
34 Rear left wheel speed sensor circuit system
35 Rear wheel speed sensor circuit system (1)
36 Rear wheel speed sensor circuit system (2)
41 Steering wheel sensor (ST1) circuit system (open circuit)
42 Steering wheel sensor (ST2) circuit system (open circuit)
43 Steering wheel sensor (ST-N) circuit system (open circuit)
44 Steering wheel sensor circuit system (short circuit)
45 Steering wheel sensor (ST-N) circuit system (short circuit)
71 Engine-ECU communication circuit system
72 Engine-ECU circuit system
73 Engine-ECU circuit system
74 A/T-ECU communication circuit system
76 ABS circuit system
Automatic transmission - Chassis manual section 23
With a flashing N lamp there are two possibilities of what it could be.
If it flashes at 1Hz, once a second, then it will be either,
Input speed sensor
Output speed sensor
Solenoid valve
Out of phase at shift points
A/T control relay system
If it flashes at 2Hz, twice per second, the ATF temperature is too high and you should stop to allow it to cool down.
11, 12 and 14 all relate to Throttle position sensor system (Vehicles without TCL) and Accelerator pedal position sensor system (Vehicles with TCL)
Code
11 Short circuit
12 Open circuit
14 Sensor maladjustment
15 Oil temp sensor system Open circuit
21 Crank angle sensor system Open circuit
22 Input shaft speed sensor Open/Closed circuit
23 Output shaft speed sensor Open/Closed circuit
26 Stop lamp switch system Short circuit
31 Low and reverse solenoid valve system Open/Closed circuit
32 Under drive solenoid valve system Open/Closed circuit
33 Second solenoid valve system Open/Closed circuit
34 Overdrive solenoid valve system Open/Closed circuit
35 Reduction solenoid valve system Open/Closed circuit
36 Damper control clutch solenoid valve system Open/Closed circuit
41 1st gear ratio does not meet specification
42 2nd gear ratio does not meet specification
43 3rd gear ratio does not meet specification
44 4th gear ratio does not meet specification
45 5th gear ratio does not meet specification
46 Reverse gear ratio does not meet specification
51 Abnormal communication with Engine ECU or Abnormal communication with TCT ECU
52 Damper control clutch solenoid valve system Defective system
54 A/T control relay system Short circuit to earth/ open circuit
56 N range lamp systems Short circuit to earth
71 Malfunction of A/T ECU
Error codes
Code
63 ABS – ECU
Code
Input speed sensor
Output speed sensor
Solenoid valve
Code
11 Short circuit
12 Open circuit
- paulenz
- PranešimaiCOLON 3122
Na jau idomiau. Anglu nelabai kertu,tai nesupratau,kam antras kodu stulpelis skirtas.
Bet,kaip supratau,mano ABS lempute rodo tokias klaidas:
Tai reiskia,kad visu ratu ABS jutikliai trumpina ar netaip supratau?21 Front right wheel speed sensor Short circuit
- kasrupi
arba negauna sroves
rytoj pazadu atsigauti ir pasitaisyti, jei kokiu nesamoniu pribursiu
- paulenz
Aha. O ta antra dalis apie TCL. Kas cia per velnias?
- kasrupi
TCL - kitais zodziais traction control
Jei nori daugiau, teks tau per si vakara ismokti anglu
prasau
http://www.mitsubishi-motors.co.za/feat ... ry/TCL.asp
prasau
- paulenz
As labai negabus kalboms.
Na kaip supratau,TCL yra traukos kontrole,jo?
Tai tokio dalyko mano galante kaip ir neturetu but.
- Spikas
- PranešimaiCOLON 214
paulenz, speju kad pas tave viskas tvarkoje ir jokiu klaidu nera. Taip pat manau kad, skirtingos masinos i ta 1 jungties pino uztrumpinima, reaguos skirtingai. Kaip pvz. pateiksiu savo masinos reakcija i uztrumpinima: jei klaidu nera ABS lempute tolygiai mirksi, jei butu klaida ismirksetu klaidos koda. Chek Engine lempute elgiasi beveik identiskai: ijungus degima po keliu sekundziu uzgesta, po to, jei nera klaidu tolygiai mirksi, jei yra klaidu, ismirksi kaidos koda.Tavo konkreciu atveju klaidas:
meta del to kad ABS blokas negauna signalo is davikliu, masina stovi signalo nera, pradesi judeti, atsiras. Jei is tikruju neveiktu ABS davikliai, ABS sistema neveiktu ir lempute degtu vaziuojant. Pas tave kiek suprantu ABS veikia ir lempute vaziuojant nedega.
- paulenz
Na nezinau nezinau,neuzvestam varikliui kompas is daugelio davikliu tada signalu neturetu gaut,bet del to klaidu kodu nemeto. ABS pas mane veikia,lempute nedega. Bet jei ratams nesisukant,kompas fiksuoja tai,kad negauna signalo is davikliu,tai neturetu net but sugalvoti tie keturi kodai,juk jie visada turetu but ismetami. Pas Tomuka,kaip supratau,situ kodu neraso.
- Duvis
- PranešimaiCOLON 215
- UžsiregistravoCOLON 2009 05 18, 08:56
- AutomobilisCOLON 3000GT/MB S class/Stratus Cabrio02m
- SkypeCOLON dovydelis2006
- MiestasCOLON TELŠIAI
labas, na pas mane irgi dega check'as pas mane 3000gt soch, o kasnors bandete si metoda siam modeliui?
LSD Team - Labai Svarbi Draugija
- doS
- PranešimaiCOLON 202
- UžsiregistravoCOLON 2009 05 26, 00:32
- AutomobilisCOLON Eclipse 1g
- SkypeCOLON drag00n666
Hm... Pas mane yra tik elektroninis voltmeras jei teisingai suprantu kas tai isvis per daiktas. Imanoma kaip nors kitaip patikrint tas klaidas clipsei 94m?
Paskutinį kartą redagavo 1 doS. Iš viso redaguota 2009 kartus.
Eclipse 1g, Raudona
Ford Fiesta EX
BMW 520 EX
Eclipse 1g Juoda EX
Audi 80 (bulka) EX
Ford Fiesta EX
BMW 520 EX
Eclipse 1g Juoda EX
Audi 80 (bulka) EX
- PranešimaiCOLON 11304
Elektroninis (ne elektrinis ) per "tūpas" tokiems dalykams... Paprasčiau bus diodu pasinaudotdoS rašėCOLONHm... Pas mane yra tik elektrinis voltmeras jei teisingai suprantu kas tai isvis per daiktas. Imanoma kaip nors kitaip patikrint tas klaidas clipsei 94m?
- doS
Ir tokio namie neturiuZyXEL rašėCOLONElektroninis (ne elektrinis ) per "tūpas" tokiems dalykams... Paprasčiau bus diodu pasinaudotdoS rašėCOLONHm... Pas mane yra tik elektrinis voltmeras jei teisingai suprantu kas tai isvis per daiktas. Imanoma kaip nors kitaip patikrint tas klaidas clipsei 94m?
Eclipse 1g, Raudona
Ford Fiesta EX
BMW 520 EX
Eclipse 1g Juoda EX
Audi 80 (bulka) EX
Ford Fiesta EX
BMW 520 EX
Eclipse 1g Juoda EX
Audi 80 (bulka) EX
- Vieede_G
- UžsiregistravoCOLON 2009 10 11, 09:46
- AutomobilisCOLON Mitsubishi Galant 93 2.0 V6
- SkypeCOLON gintaras_v
- MiestasCOLON Panevezys
Sveiki vyrai.
Ka daryti man liamda zondas i dankrata kala :DDDD (ok ok. prikolai baigti)
Esme tokia Man ismeta koda NR.41 Injectors circuit malfunction
Suprantu kad problema su purkstukais, bet klausimas nuo ko pradeti ieskoti problemos. Jeigu gerai suvokiu tai purkstuku darba reguliuoja kompas. Ar mano zinios prasto?
Please. Need help
Please. Need help
Only god can Judge me
- Vieede_G
ACIU chebra. "Labai padedat" kompa pasikeiciau, niekas nepasikeite. krastosi variklis siaubingai. galima sakyti is vis nedirba.
- paulenz
Galbut kazkuris purkstukas blogas. Arba nuo kompo i ji signalas neateina.
