Tepalai ziema ir vasara
- PranešimaiCOLON 3563
Re: Tepalai ziema ir vasara
tai koki reduktoriiu ? ju ne vienas yra gali skirtis.
- ZeRoX
- PranešimaiCOLON 2140
- MiestasCOLON Panevėžys
Lancer 1996 4wd universalasZND007 rašėCOLONtai koki reduktoriiu ? ju ne vienas yra gali skirtis.
- PranešimaiCOLON 1916
- AutomobilisCOLON awd
- SkypeCOLON pol3w4z
- MiestasCOLON Kaunas-Norge
Gale tyltas, o prieki idomiai prijungtas reduktorius prie dezes per pusasio isejima, nemates tokio perdavimo buvau..ZND007 rašėCOLONtai koki reduktoriiu ? ju ne vienas yra gali skirtis.
ZeRoX rašėCOLONLancer 1996 4wd universalasZND007 rašėCOLONtai koki reduktoriiu ? ju ne vienas yra gali skirtis.
Engine 4G92
· Capacity : Capacity 3,8 liter
: Filter 0,3 liter
· Use : Normal
· Intervals : Change 15000 km / 12 months
· Products
: MaxLife Synthetic 5W-40
Show all products
: MaxLife 10W-40
: DuraBlend MXL 5W-40
Differential, rear (4x4)
· Capacity : Capacity 0,8 liter
· Use : Normal
· Intervals : Check 30000 km / 24 months
: Change 90000 km / 72 months
· Products
: HP GL-5 80W-90
Show all products
Transaxle, automatic 4/1
· Capacity : Capacity 6 liter
· Use : Normal
· Intervals : Check 15000 km / 12 months
: Change 45000 km / 36 months
· Products
: MaxLife ATF
Show all products
Transaxle, manual 4/1
· Capacity : Capacity 1,8 liter
· Use : Normal
: Change 75000 km / 60 months
· Products
: SynPower TDL 75W-90
Show all products
: DuraBlend GL-4 75W-80
: DuraBlend GL-4 75W-90
Transferbox
· Use : Normal
· Products
Show all products
Hydraulic brakes/clutch system
· Use : Normal
· Intervals : Change 30000 km / 24 months
· Products
: Brake & Clutch Fluid DOT 3/4
Show all products
Power steering
· Capacity : Capacity 0,9 liter
· Use : Normal
· Products
: MaxLife ATF
Show all products
: ATF Type D
Cooling system
· Use : Normal
· Intervals : Change 60000 km / 48 months
· Products
: MaxLife Coolant AF
Show all products
: MaxLife Coolant AF 50/50 RTU
dekoju labai
O koki tepala pilt i '08 metu 1.5 DI-D varikli (70kW) ?
- PranešimaiCOLON 47
- UžsiregistravoCOLON 2011 01 28, 22:34
- AutomobilisCOLON Galant 2g
- MiestasCOLON Panevezys
Koki tepala reiktu pilti i Colta 92m (CAO) 1.6 Benzina (83kw) kuris bus naudojamas TIK megejiskam sportui vasaros metu ?
10W60, sakyčiau...
- PranešimaiCOLON 149
- UžsiregistravoCOLON 2010 10 02, 20:49
'98 2.5L 120kw Galantui...
http://www.castrol.com/castrol/sectionb ... Id=7073092
Magnatec 10W-40 (?) - Jei gerai supratau, čia ne sintetiniai?
Na ok, paaiškinkit man. Pilu 5w30 sintetinius, nei žiemą problemų, nei vasarą. Ir kompensatoriai patys nustojo kalt, tai jaučiuosi, kad viską darau teisingai.
Žiemą tik prie -30 turėjau problemų dėl seno akūmo - ne iš pirmo karto užsikūrė, lemputės užvedimo metu stipriai prigeso, etc. Na ne kasien būna tiek, bet prie -25'C puikiai vedasi, ant laisvų apsukų per ~5 min pašyla. Įjungi šildymą ant stiklų, kol sniegą nuvalai nuo visos mašinos, tai jau ledas nuo priekinio stiklo būna atšokęs ir šlapias, o salone jau pakankamai šilta. Po ~10 min variklis dirba savo darbinėj temperatūroj. Tiek žiemą, tiek vasarą, rodyklė užkyla tiek pat.
Per 2 metus gaunasi 3 tepalo pakeitimai, variklis 300k perlipęs, bėga tik per dangtelį (TA buvo nepraleidus kartą dėl to, ploviau variklį), dapilinėt niekada nereikėjo.
Tai visgi, likt prie savo 5w30 ar pilt 10w40, kaip rekomenduoja Castrol saitas? Ir dar klausimas, čia 10w40 yra gamykliniai nurodymai, ar Castrol sugalvoti?
Geriau lik prie 5w30
- PranešimaiCOLON 3
- UžsiregistravoCOLON 2012 08 14, 21:09
- AutomobilisCOLON Mitsubishi carisma
- SkypeCOLON mantukas445
Sveiki , gal zinot kokia variklio alyva pilti i Mitsubishi carisma 1997m 1.9td 66kw su turbina ? Zmones padekit , reikia man iki rytojaus suzinoti, kol kas esu apsistojes ties „CASTROL EDGE TD“ (5W-40), Aciu is anksto!
- Ignys
- PranešimaiCOLON 84
- UžsiregistravoCOLON 2012 02 24, 17:08
- AutomobilisCOLON Mitsubishi Carisma '97 1,9TD
- MiestasCOLON Kaunas-Varniai
aisku labai per velu i klausima atsakyti, bet tiek to, as i carisma 1.9td pilu Motul 5w40 sintetika, tai pagerejo masinos darbas zymiai nuo pusiau sintetiniu 10w40, tiesa brangiau kainuoja, ir sunaudoja truputeli daugiau alyvos bet smagiau dirba matoriukas
Mitsubishi Carisma '97 1,9TD GLX
Gal kas naudojate arba kokiu atsiliepimu girdeja apie DynoCat alyvas?
- Nowone
- PranešimaiCOLON 840
- UžsiregistravoCOLON 2006 06 23, 17:01
- AutomobilisCOLON evo V
Dynocat yra normali USA alyva. Gal tik Europoj nelabai zinoma. Bet norgej ja nemazai kas naudoja sau nori ja pilt ar servise naudot?
- PranešimaiCOLON 2
- UžsiregistravoCOLON 2013 08 31, 15:37
- AutomobilisCOLON Galant 2.4 GDI Avance
ką tik nusipirkau Galantą 2001 metų benzas, 2,4 GDI Avance. Kokius variklio tepalus geriausia būtų pilti? Girdėjau, kad GDI varikliai lepūs, taigi norisi ir supilti tai kas reikia, nepataupyti šitoj vietoj. Šaltas ciksi (sako kompensatoriai, gali būti dėl to, kad tepalai prieš 20 000 keisti) ir pacypia dirželis, o šiaip važiuoja gerai , traukia. Nuvažiavusi 168 000. Dujų nestatysiu, važinėsiu ant benzo.
Dėkingas (ilgai ieškojau forume, bet neradau)
Mitsubishi Galant 2,4 GDI Avance , '01
